steering wheel vibration
LEXUS
AREXER
'97 Lexus ES300 110000 mileage.Have recently replaced all struts and brake rotors and have had tires inspected and balanced but car has now developed a shimmy in steering wheel at speed of 30 mph and less. At higher speeds the vibration in steering wheel disappears. what do you suggest?
BG
Jan 29, 2007 at 4:41 AM
GARFIELD
  • 197 POSTS
I would look at having my front end suspension parts like the tie rod ends checked for wear, since they can give you a shimmy too.
Jan 29, 2007 at 5:08 AM
2CARPRO JACK
  • 11,533 POSTS
I know the tires were inspected , but have them rotated front to back, not an x pattern and see if it changes anything, kinda sounds like a tire is seperating
Jan 29, 2007 at 7:31 AM
KIN CHAN
  • 453 POSTS
good good good vibrations!!!..must be in california..heh heh heh heh...
have a shop chk ur U-joints and make sure all tires are balanced!!!.......let me know how it come out...
Feb 20, 2007 at 9:33 AM
LOSTINMARS
  • 222 POSTS
get the cv joints checked and the carrier bearing on the passenger side axle.
Feb 20, 2007 at 9:12 PM
ARC123SAC
  • 5 POSTS
Brake Masters will check this for free and tell you what needs to be repaired if you are still having a hard time with it.
May 7, 2007 at 5:49 PM
