should i buy is it worth it and 4 how much
LEXUS
LACOSANOSTRA
1990 lexus ls400 ,it has oil leak,idle problem has 2 keep foot on gas and brake so it wont stop, tem-time burned out nothing shows up, has dents but my concern is the 236,174 miles am i fool 4 thinking of buying it can u give me the advise i really need?!
Mar 4, 2007 at 2:28 PM
BRUCE HUNT
  • 3,754 POSTS
You need to ask yourself if you are able to do the work on the car yourself and know that with that many miles on it, there will be a constant need to be fixing little things. If not, this car will nickel and dime you to death.
The oil leak can range from a small stupid leak like a valve cover to a more serious one like an oil pan leak or a seal, etc.
Time and temp gauges are replaceable and the idle can be generally pretty simple.
Recycle to the first para and ask it again and again.
Mar 4, 2007 at 9:49 PM
