lexue es300 "check engine" light going off
1930 LEXUS
VLAD
Hello. my name is Vlad.I have a 2002 Lexus ES 300. It has not been in any accidents and has only 46,000 miles on it. I checked all the plugs that I found. I went to get a computer diagnostic due to the "check engine" light going off, and I received 2 codes: P1130 and P1135 (fuel air metering), however the men at the shop did not know the meaning of these codes, so I am hoping you can help me and tell me if it's the sensor and if it is, where is it located.
Thank you for your help. :lol:
Feb 21, 2007 at 10:47 AM
KIN CHAN
  • 453 POSTS
easy!!!!..both are manufacture code for Air fuel ratio sensor ..1 is the sensor the other is the heater ....it is the new version of oxygen sensor that imports using it for a long time ..i fixed a 04 tacoma like that...make sure u take it to a shop with a scanner called master tech ...thats the original factory scanner and thats the only way to test it and verfly ur problem....so far aint no known way other than factory scanner to verfy the signal except master tech .....good luck!!!
Feb 21, 2007 at 10:58 AM
