2001 Lexus LX 470 Height Control Problem
2001 LEXUS LX 470
ADAMTSAI
Engine Mechanical problem
2001 Lexus LX 470 V8 Four Wheel Drive Automatic
Recently my Lexus has gone down to the "low" position on the height control and it won't move out of that position. I tried moving it back to normal height but it won't budge. Also the the "off" light for the height control keeps flashing. What could be the problem with my lexus? Thank you!
Jan 19, 2010 at 11:12 AM
RENDERFULLER
  • 7 POSTS
A few things could be wrong here. There is a fluid self leveling suspension setup in the lx470. There is a fluid pump under the hood on the passenger side top corner mounted to the firewall, It pumps fluid into the shocks and raises and lowers the vehicle when you push the ride height adjustment button. If the pump is out the vehicle will not raise or lower and the off light will flash. Also it could be that the shocks are leaking and have let all of the fluid out of the system which if left for a period of time unchecked will lead to pump failure. There is a fluid resevoir under the hood on top of the pump it is labled and should be filled between low and high mark with lexus suspension fluid. It could also be that your ride height sensons are out of adjustment or broken. There are two height sensors behind the front tires near the top they can be adjusted with a 10mm wrench and there is one sensor mounted to the drivers side rear four link on top by the rear end. I would not recomend trying to adjust them yourself because they need to be set exactly to match each other or the computer will think somthing is wrong with the vehicles suspension and not function. By the sound of your example i would say that Your ride height sensors are broken or out of adjustment. When a sensor malfunction exists the vehicle will not even try to raise or lower because it doesnt know which way to go. Good Luck.
Aug 2, 2010 at 6:01 PM
