I have a 6 disc cd player and there is a stuck cd. I cannot get it to eject or play. Any suggestions?
Sep 26, 2009 at 8:53 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
You should not try and force the CD out, as the mechanism is very delicate, i would get a radio tech to inspect this problem, most stacker's do have a manual eject button but you will need a tech to check this for you as it is just a small hole in the case which you insert a tool to manually eject the disk.
