Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lexus
LS 400
Brakes
Rotor
Replace/Remove
2000 Lexus LS 400 rear rotor removal
2000 LEXUS LS 400
150,000 MILES • V8 • 2WD • AUTOMATIC
GBANDY
MEMBER
1 POST
FOLLOW
I have removed brake calipers and axle bolt as well as removed disc screws. Cannot get the rotor removed. What else am i missing? Thanks
Jul 19, 2008 at 1:11 PM
KHLOW2008
CERTIFIED EXPERT
Hi gbandy,
The rotors are tightly fitted onto the hub, you need to use some rust remover and bang the area where the wheel sits to get it loosened up.
If you want to remove only the rotors, install back the axle nut first.
Jul 20, 2008 at 2:43 PM
