After the car has warmed up, this often happens while driving the car:
While in motion, the brake pedal is applied;
resulting in this:
a) the sound system cuts out and comes back on normally about 2 seconds later, even if the brake pedal is still in use;
b) both headlights flicker momentarily;
c) the cruise control disengages and shuts itself off;
Note:
Switching the headlights from Low beam to High beam will also cause the same 3 results (a, b & c) as listed above. The brake pedal does not have to be pressed down at the time the Hi - Lo beams are employed.
Perhaps you are able to suggest a fix for my problem?
resulting in this:
Note:
Dec 31, 2008 at 6:41 PM
