1995 Lexus LS 400 gas smell
1995 LEXUS LS 400
139,000 MILES • V8 • 2WD • AUTOMATIC
JEFF2010
had a new starter put on my lexus. After the repair I can smelll gas inside car when i have the heat on.
Jan 8, 2010 at 9:16 PM
Could be running rich below will cause it-if there's no actual leakage and charcoal canister is not saturated with fuel
Probable causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jan 8, 2010 at 9:22 PM
