1993 Lexus LS 400 Will not start
1993 LEXUS LS 400
17,200 MILES • V8 • 2WD • AUTOMATIC
BURGERMAN
Engine will crank and run for about 1 second then quits.
I pulled OBD code and came up with a "15". The only info I have found on this code is "Ignition Number 2". Does this point to an Ignition control module problem. Thank you for any info.
Walt
Aug 27, 2008 at 6:32 AM
2CARPRO JACK
  • 11,533 POSTS
Hope you can read these,they are th eflow chart for code 15 - ignition signal circuit
https://www.2carpros.com/forum/automotive_pictures/1639_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/1639_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/1639_3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/1639_4_1.jpg
Aug 27, 2008 at 8:15 AM
BURGERMAN
The images are too small and blurry to read.
Aug 27, 2008 at 8:21 AM
2CARPRO JACK
  • 11,533 POSTS
The you need to go here
https://www.2carpros.com/kpages/auto_repair_manuals.htm
engine performance, tests w/codes, code definitions
Aug 27, 2008 at 10:15 AM
BURGERMAN
[quote:e42789ca53="2CarPro Jack"]The you need to go here
engine performance, tests w/codes, code definitions[/quote:e42789ca53]
I went to that site, on your recommendation, using the link, you provided. It is a working site but does not allow one to purchase a manual. You might want to check it out, since it is faulty.
Aug 27, 2008 at 10:52 AM
BLACKOP555
  • 10,386 POSTS
you would have to click on the mitchel 1 link. blue right under the picture.
Aug 28, 2008 at 8:36 PM
