Computer problem
1993 Lexus LS 400 V8 Two Wheel Drive Automatic 189.50 miles
This car is showing code #14 no ignition #1signal and code #15 no ignition #2signal. It is sometimes hard to start and will only run for about 5 minutes and will cut off. Sometime won't crank again. When running it does not run well sometimes, It misses and runs rough I have noticed that when it cuts off that one of the igniters is getting much hotter than the other. Is this both crankshaft sensor, and camshaft sensors indications or something else.
Jul 30, 2010 at 11:54 PM
