1993 Lexus LS 400
1993 LEXUS LS 400
EDDIE MAGALLANEZ
Transmission problem
1993 Lexus LS 400 V8 Two Wheel Drive Automatic
TRANSMISSION WON'T SHIFT OUT OF FRIST WITH
HEAD LIGHTS ON. THE MOMENT THE HEAD LIGHTS ARE TURNED OFF THE TRANSMISSION WORKS PERFECTLY
Oct 13, 2008 at 5:16 PM
JAMES W.
  • 2,394 POSTS
Looking at the wiring diagrams, the only place these two systems even come close to each other is in the dash. Other than that they are totally independant.
Questions; Do you a digital dash?
Are your dash lights/gauges "dimable" for night driving? If they are dimable, turn the switch as low as you can,preferably off, and see what happens to the shifting. Let me know
Oct 13, 2008 at 9:37 PM
EDDIE MAGALLANEZ
[quote:3fa8463578="James R. Weizel"]Looking at the wiring diagrams, the only place these two systems even come close to each other is in the dash. Other than that they are totally independant.
Are your dash lights/gauges "dimable" for night driving? If they are dimable, turn the switch as low as you can,preferably off, and see what happens to the shifting. Let me know[/quote:3fa8463578]
mr. weizel no its not a digital dash only the air condition, clock, & tempersure display are digital. it dose have dimmer switch, i turned it off & still have the same problem,when i turn on the head lights the reverse indcator lights up on the dash board & wont shift
Oct 17, 2008 at 12:59 PM
IMPALASS
  • 3,112 POSTS
Hello
Please go to the junction fuse box on the left side of the steering column.
There is a fuse there for “STOP” – 25A. Please pull it and then drive and see if that fixes it.
If not, replace that fuse and in the same area there is a 15A “TAIL” fuse. Please drive it again and see if that fixes it.
Let us know.
Oct 23, 2008 at 9:30 PM
