Hello
The great news if for you is you don't have to drop the tank. I have provided the info for you.
Preparation
Disconnect negative battery terminal.
Drain fuel into an approved container.
Remove front luggage compartment cover.
Disconnect fuel pump electrical connector.
Remove rear seat back.
Remove access hole plug.
Fuel Pump Removal
Remove fuel pump set plate.
Pinch hose clamps and slide fuel hose toward pump.
Remove three pump bracket retaining screws.
Lift fuel pump from tank.
Fuel Pump Disassembly
Remove fuel pump wires.
Pull lower end of pump away from pump bracket.
Remove rubber cushion.
Remove filter retaining clip and filter.
Reverse procedure to install. Use a new tank gasket and note the following torque values:
Pump bracket - 48 in.lbs (5.4 Nm)
Pump set plate - 26 in.lbs (2.9 Nm)
Nov 9, 2008 at 1:32 PM
