I want to know were can I go to get the wiring layout of the power windows from the power window switch to the fuse block under the dash doard.I replace the window switch and the 30amp fuse and still does not work.the moters are working fine because I tested them individualy. I was puting a music cable thru the driver side fire wall and some how I think I cut a wire thats when the windows stop working.If I take it to a shop will it be an expensive jod to fix.
thank you for taking your time in answering this e-mail.
May 9, 2009 at 5:36 PM
