1990 Lexus LS 400 front end wobble
1990 LEXUS LS 400
223,000 MILES • V8 • 2WD • AUTOMATIC
GREENEBA
the front end shakes and wobbles only when i hit the brakes, could this be the front end or warped rotors?
Apr 29, 2010 at 2:37 PM
MERLIN2021
  • 17,250 POSTS
Wobbles when brakes are used is normally the rotors need to be changed. But with the mileage on yours check both. Before you remove the tires jack it up, and shake the tire back and forth, then grab at top and bottom and shake again, any movement means worn front end parts too!
Apr 29, 2010 at 2:46 PM
