2003 Lexus GX 470 electric windows
2003 LEXUS GX 470
79,000 MILES • V8 • 4WD • AUTOMATIC
ALDRIDGEDAVID
How do I remove the inside drivers door panel to access the window switches? I tried to pry it, but it didn't seem to be attached like others I've removed, and I don't want to break it. Each window works at the door, but not at the master switch at drivers door. I think it's only a loose connection. Your thoughts?
Mar 18, 2010 at 12:42 AM
KHLOW2008
  • 41,814 POSTS
Hi aldridgedavid,
Thank you for the donation.
Problem could be a loose connection or a bad master switch. The circuit that leads to the other doors could be faulty.
I have sent the procedures to your email as the file is too large for me to post.
Mar 19, 2010 at 12:11 PM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay and error.
I had difficulty sending out the files and I have since broken the files into 3 parts. I believe they should be sent out correctly now.
Let me know if the files turns out correctly.
Please use the " Reply to question " link at bottom of page so that notification would be sent to me and I can get back to you once I am online.
Mar 30, 2010 at 9:16 AM
