1998 Lexus GS 300
1998 LEXUS GS 300
VOIGHTTA
1998 Lexus GS 300 900000 miles
Where is the thermostat located on a 1998 Lexus GS 300 and how is it replaced?
Apr 27, 2010 at 6:13 PM
https://www.2carpros.com/forum/automotive_pictures/12900_t_7.jpg
REMOVAL HINT: Removal of the thermostat would have an adverse effect, causing a lowering of cooling efficiency. Do not remove the thermostat, even if the engine tends to overheat. 1.Drain engine coolant. 2.Disconnect water inlet from water pump, and remove thermostat. a.Remove the 2 nuts holding the water inlet to the water pump, and disconnect the water inlet from the water pump. b.Remove the thermostat. c.Remove the gasket from the thermostat. INSPECTION HINT: The thermostat is numbered with the valve opening temperature. a.Immerse the thermostat in water and gradually heat the water. b.Check the valve opening temperature. Valve opening temperature: 80 - 84 °C (176 - 183 °F) If the valve lift is not as specified, replace the thermostat. c.Check the valve lift. Valve lift: 8.5 mm (0.335 inch) or more at 95 °C (203 °F) If the valve lift is not as specified, replace the thermostat. d.Check that the valve is fully closed when the thermos is at low temperatures (below 40 °C (104 °F)). If not closed, replace the thermostat. INSTALLATION 1.Place thermostat in water inlet. a.Install a new gasket to the thermostat. b.Align the jiggle valve of the thermostat with the protrusion of the water inlet. 2.Install water inlet. Install the water inlet with the 2 nuts. Torque: 9.0 Nm (80 inch lbs.) 3.Fill with engine coolant. 4.Start engine and check for coolant leaks radiator https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Apr 28, 2010 at 3:59 AM
