1995 Lexus GS 300 electronics are slow
1995 LEXUS GS 300
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIPTOE
Hello I have a 1995 Lexus GS300 with 144000 miles on it. Lately it seems as though some of my electronics are running a little slow. The windsheild wipers aren't as fast as they used to be, my HID headlights flicker like they aren't getting enough power, my power windows go up slowly, and even my cd player plays the cd's slower than usual. I've just replaced the battery to see if that fixed the problem but still the same and the altenator was tested and is in great shape. Could it be a bad fuse or maybe even the power wire coming off the battery?
Aug 11, 2010 at 7:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
It is not caused by a faulty fuse, fuses protect circuits so the components on that circuit will either work or not work. Most likely it is a loose ground. Check the battery terminals to ensure they are clean and free of any acid build up. Also ensure they are tightened properly. Check the same cables at the other end which will be at the alternator.
Aug 12, 2010 at 1:48 AM
