2000 Lexus ES 300 Timing Belt
2000 LEXUS ES 300
190,000 MILES • 6 CYL • FWD • AUTOMATIC
LOU YORIO
I got two opinions on timing belt issue, I agree that my timing belt needs to be replaced, I had car since 28,000 and have not replaced yet. One mech. says I need to replace belt only $369 repair, the says I need to replace water pump and timing belt at same time $660 repair, big difference in repair cost. Who is right?
Do you have other suggestion?
Jan 31, 2009 at 7:41 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Both prices are about correct for the work done, water pump job may be a tad high, but the difference is that the water pump is not a mandatory replacement when doing a cam belt, some opt to do it as a matter of precaution as it is all stripped down to the point of replacement when you do the belt, this is really a matter of choice, but the pump if ok dose not need to be replaced with the belt.
mark (mhpautos)
Jan 31, 2009 at 7:52 AM
