2000 Lexus ES 300 can not turn key in ignition
2000 LEXUS ES 300
153,500 MILES • 6 CYL • FWD • AUTOMATIC
JOHNIESIMMONS
Jan 11, 2010 at 8:33 AM
JOHNIESIMMONS
key will not turn in ignition
Jan 11, 2010 at 8:59 AM
MATHIASO
  • 1,209 POSTS
Hello and welcome to 2carpros
First of all make sure the car is in park.
If not, the key won’t turn.
If the car is in park and the key do not turn remove it, and spray a small amount of lock lubricant in the cylinder.
Insert the key inn and while taping on it softly with the palm of your hand or a hammer (softly) turn it.
If it does not work, spray more lubricant and do the same thing until the key turns.
The key cylinder should be replaced when you get it started.
Jan 11, 2010 at 10:29 AM
