2000 Lexus ES 300 120k service question
2000 LEXUS ES 300
120,150 MILES • 6 CYL • AWD • AUTOMATIC
HEALTHPOLICY
I have a 2000 ES with 120,150 miles on it. I had the oil changed today at the Lexus dealership. I was told I also need the 120k service which is the same as the 60k service. I was given a handout on the 60k service. The cost for the service is $1550.62 What is really a "must" with the service? 1/2 of it seems to be routine inspection. The timing belt I understand. Also, what does timing belt replacement usually cost? I noticed another forum member posted the charge at their dealership for the 60k services was $600.
thanks in advance,
Dana
Oct 21, 2008 at 5:19 PM
BLACKOP555
  • 10,386 POSTS
thats a bit steep for the average.
what do they all list they are going to do then i can give you a better answer.
Oct 21, 2008 at 7:06 PM
HEALTHPOLICY
This is the list I was given.
Replace engine oil and oil filter
Rotate tires
Measure thickness and runout of brake rotors
Measure thickness of brake pads
Replace air conditioner filter
Replace brake fluid
Inspect the following:
___Axle shaft boots
___Ball joints and dust covers
___Body
___Brake lines and hoses
___Drive belt
___Engine coolant
___Exhaust pipes and mountings
___Fuel lines and connections
Replace spark plugs
Visually inspect brake pads, calipers
and rotors
Replace timing belt
Replace engine V belt
Replace wiper blades.
Oct 21, 2008 at 7:23 PM
BLACKOP555
  • 10,386 POSTS
ill try and find a estimate for a timing belt replacement, thats a expensive job.
for what they listed i woudl say thats a bit more then the average tune up and a reasonable price.
check around for other quotes, you might find lower dependent on the service rate, a independent mechanic will be cheaper,
Oct 21, 2008 at 8:11 PM
HEALTHPOLICY
The service manager stated the timing belt and v belt would be $600. But he couldn't explain where the other $900 was.
Dana in
Oct 21, 2008 at 9:53 PM
BLACKOP555
  • 10,386 POSTS
600 for the timing belt parts and labor is a good price.
the other 900 is a bit high for what else they are doing, i would go no higher then 1000 at the most, 900 bucks for what they listed is quite high.
Oct 22, 2008 at 7:33 PM
