1996 Lexus ES 300 trans fluid
1996 LEXUS ES 300
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALANS
where is the trnas fluid refill port?
Mar 31, 2008 at 9:40 PM
2CARPRO JACK
  • 11,533 POSTS
Try putting it in neutral, if the neutral safety switch is messing up, it may work inneautral. Otherwise need to test for power at the small wire on the starter with key in crank position and go from there. If it has power, the starter is bad,if not get back to me and we will figure out where it is being stopped
Apr 10, 2008 at 3:42 PM
