1996 Lexus ES 300 Oil Leak/Cracked blocks
1996 LEXUS ES 300
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
USEAGLE83
I just bought a used vehicle and thought that it would be a good deal. After a few days the car started leaking oil. I took it to a mechanic and he said that the car has two cracked front blocks and one in the back. He quoted that it will be between $800.00-$1200.00 to fix. The mechanic seemed very honest and professional and told me that I could just refill oil, but should also replace the timing belt sooner than usual, because the oil leaked onto the timing belt. I don't really have the funds to pay for the repair and was wondering if there is any cheaper way to fix it. I read about CD2 Engine Oil Stop Leak and wanted to know if that might help with the cracked blocks.
I would appreciate any advice you can give me.
Thank you
May 26, 2010 at 9:45 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would go get a second opinion on this, as normally you do need to magna flux or ultra sound a block for a crack and if it was the repair is often a new block, i would just for now get a second opinion and see what they say.
mark (mhpautos)
May 26, 2010 at 10:55 PM
