1994 Lexus ES 300 transmission fluid dipstik
1994 LEXUS ES 300
LIZZIE24
Engine Mechanical problem
1994 Lexus ES 300 6 cyl Automatic
HELP!! I took the transmission fluid dipstick out to check the level as per normal but now no matter what i do it wont go back in again! What could the problem be? How do i fix it and is it ok to drive without it until its sorted? Your help is greatly appreciated. Thanks
Mar 18, 2010 at 8:06 PM
DAVE H
  • 13,384 POSTS
CHECKING FLUID LEVEL
Transmission & Transaxle
Check transmission fluid with engine and transmission at 158-176°F (70-80°C). Park vehicle on a level surface and set parking brake.
With engine idling and parking brake engaged, move shift lever from "P" to "L" position and return to "P" position. Remove dipstick and clean it. Insert it back fully into tube. Pull it out and verify fluid level is in HOT range on dipstick. Add fluid as necessary.
Mar 21, 2010 at 8:04 AM
