1994 Lexus ES 300 Car is overheating after a New Radiator h
1994 LEXUS ES 300
249,700 MILES • 6 CYL • FWD • AUTOMATIC
MCFARLANDTE
Hi
I recently had a new radiator installed on my car and now it overheats at the slightest distance driving. I can't drive on the highway anymore at 60mph or even if Im on the back roads at 45mph. I took it back to the mechanic he supposedly flush the coolant and filled it back up but I continues to do the same thing the temp gauge goes up. Also my heat won't work either now it use to before he replaced the radiator. What could be the problem?
Thanks
Feb 12, 2008 at 9:35 AM
JOHNYPHANTOM
  • 37 POSTS
sounds like a bad thermostat , might also have an air pocket in cooling system , but id check the thermostat first , symptoms you are having indicate a bad thermostat ( it could also be the water pump )
Feb 12, 2008 at 10:16 AM
