1994 Lexus ES 300 Break Booster
1994 LEXUS ES 300
194,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERTPOTTS
Is it possible if the break booster is out or not working properly is it possible only one side of my breaks would work ? How exactly would I know it's not working ?
Nov 7, 2010 at 8:01 AM
Is it possible if the break booster is out or not working properly is it possible only one side of my breaks would work ? Check the brake booster turn ignition switch off pump the brakes to exhaust the vacuum-hold it in and then start the car, the pedal should drop slightly if the booster is working-check the ABS unit, combination valve and master cylinder
Nov 7, 2010 at 9:12 AM
