1992 Lexus ES 300 wonlt run
1992 LEXUS ES 300
REDDFOXX330
Engine Mechanical problem
1992 Lexus ES 300 6 cyl Front Wheel Drive Automatic
in know the injectors wonlt fire but after it sits for a waile some times it will run then it shuts down like you turned the key off then i wonlt start back up fuel presure is good
Dec 13, 2009 at 9:27 PM
Have you already checked the injectors? Are you getting a pulse to them when it doesn't start? Will it start with starting fluid when this happens?
Dec 18, 2009 at 11:52 PM
REDDFOXX330
i have no injector pulse it will start with eather
Dec 20, 2009 at 6:57 PM
Check for a loose connection to the computer. I have seen them come loose and cause crazy problems. If everything looks good, have the computer checked.
Let me know what you find.
Dec 20, 2009 at 11:45 PM
REDDFOXX330
all of the connections are good how do i test the computer
Dec 27, 2009 at 7:59 PM
