1992 Lexus ES 300 CV axle remove w/ carrier bearing
1992 LEXUS ES 300
199,000 MILES • 6 CYL • FWD • AUTOMATIC
MR.MIKE68
MEMBER
1 POST
FOLLOW
How do I get the inner axle out from the trans. It has a carrier bearing thats housing is a motor mount ?
Mar 25, 2010 at 5:54 PM
DOCFIXIT
CERTIFIED EXPERT
Hi
The right side correct?
Have you removed tie rod, stablizer link and streeing knuckle from lower ball joint and removed axle shaft from hub? if yes then remove bearing lock bolt and snap ring. Then pry axle from trans as in diagram
