1992 Lexus ES 300 crank position sensor
1992 LEXUS ES 300
BIGTONY2000
  • 5 POSTS
Electrical problem
1992 Lexus ES 300 6 cyl Manual 235500 miles
i would like to know where to find my crank position sensor, and if you have a pic/diagram?
Apr 30, 2009 at 6:16 AM
What's the problem here No spark ????? that your'e looking for it-I've checked it in Mit1 On demand and there's no listing having one.
Apr 30, 2009 at 6:27 AM
BIGTONY2000
  • 5 POSTS
my timing jumped and then i had my timing straightened out, now it turns over but it won't start.
but it's getting gas, and it has a spark
Apr 30, 2009 at 6:37 AM
Check the fuel pressure and for injection pulses
Apr 30, 2009 at 6:45 AM
BIGTONY2000
  • 5 POSTS
let me tell you what i did, i replaced the spark plugs, fuel pump, valve cover gaskets, flex pipe, timing belt, timing belt tensioner(hydraulic), water pump. then after that when i was driving one day going about 70 mph, i started going up a hill and it started acting real sluggish. i give it gas and it hesitated, i let up off it and it picks up a little bit. but it was like everytime i get to a hill, if i'm doing 60 before the hill, by the time i get up the hill i was doing 35 or 40.
Apr 30, 2009 at 7:04 AM
Do what I've suggested and then comeback with some results
Apr 30, 2009 at 7:41 AM
BIGTONY2000
  • 5 POSTS
okay i will
Apr 30, 2009 at 7:43 AM
BIGTONY2000
  • 5 POSTS
the fuel is pumping and getting pulse, so it's getting fuel and spark, it just won't turn over.
Apr 30, 2009 at 9:50 AM
Its getting fuel but we don't know what is the actual fuel pressure-EFI system don't like low fuel pressure. Also you've mentioned it jumped timing-You need to verify the valve and ignition timing whether its correct
Apr 30, 2009 at 3:39 PM
