when unlocking the driver door the alarm goes off. but on unlocking on passenger side OK so we open on passenger side
Oct 23, 2009 at 3:33 PM
SERVICE WRITER
CERTIFIED EXPERT
By symptom I would first start my testing at the LH door lock control switch and the door lock key switch. Might be wiring or component failure.
I can provide some testing information if you are going to do the testing. IF you decide o take it to a shop, they will already have the info.
Oct 24, 2009 at 6:50 AM
DEANMENDEZ
MEMBER
[quote:dedcee5a13="deanmendez"]Electrical problem
1990 Lexus ES 250 6 cyl Front Wheel Drive Automatic 175 miles
when unlocking the driver door the alarm goes off. but on unlocking on passenger side OK so we open on passenger side[/quote:dedcee5a13] we allready change the switches the door lock still the same problem.
Oct 26, 2009 at 11:43 AM
SERVICE WRITER
CERTIFIED EXPERT
What switches did you replace, and what else has been done regarding this problem?
Oct 26, 2009 at 3:43 PM
DEANMENDEZ
MEMBER
[quote:32b851764e="Service Writer"]What switches did you replace, and what else has been done regarding this problem?[/quote:32b851764e]
I replace the door key lock with the to switches on it
the door lock switch has to wires coming out of it.
That is all i done.
