Left Turn Signal is Dim and the hazard lights are not working
1996 CHEVROLET TRUCK
240,000 MILES
PIRATECITYVIXEN
The problem started yesterday. Truck started like normal, no issues. When i turned on my left turn signal it is very dim and the gas gage little stick is flickering with the left turn signal. There is no issue with the right turn signal. It works fine and so do my other lights.I tried to turn on my hazard lights which worked up till yesterday but they arent working either. Thought it could be a fuse but now thinking it could be a short circuit some where. Any help would be great Im completely clueless about this stuff.
Thank you
Mar 4, 2015 at 8:31 AM
HMAC300
  • 48,601 POSTS
check grounds at front and rear of truck for lights. it also may be your hazard switch which has the flasher for both hazard and t/s lights.
Mar 4, 2015 at 9:27 AM
