Hi and thanks for using 2CarPros.com. I totally understand the need for the parking brake when docking a boat. (lol) I nearly lost my truck, too.
Okay, if the front cable is attached in the cab of the vehicle, but is not moving under the vehicle, something broke. Most likely, it is the cable. What I have done is attach the directions for removal and replacement of the entire cable assembly as well as pictures to follow. Start at the park lever in the cab and following the schematics I have supplied, locate where the break is located. Since the front cable is not moving, chances are the cable anchor pin from the pivot hole in the control assembly ratchet pin has broken or come apart.
Removal:
Relieve tension on the system by having an assistant pull on the parking brake intermediate cable (2A620) or front parking brake cable and conduit while you insert a 5/32-inch drill bit into the hole provided in the parking brake control.
Disconnect the parking brake intermediate cable or front parking brake control cable from the parking brake rear cable and conduit.
To replace the parking brake intermediate cable, disconnect it from the front parking brake cable and conduit and remove it.
To replace the front parking brake cable and conduit, remove the cable anchor pin from the pivot hole in the control assembly ratchet pin.
Guide the front parking brake cable and conduit from the parking brake control and disconnect it from the frame mounting bracket. Remove cable-to-frame attaching screw, if screw is present, and slide cable from vehicle.
Installation:
Feed the front parking brake cable and conduit through the hole in the front frame mounting bracket. Push the retainer through the hole so the fingers expand over the hole.
Route the front parking brake cable and conduit around the control assembly pulley and insert the cable anchor pin in the pivot hole in the ratchet assembly.
If removed, install cable-to-frame attaching screw.
Connect the front parking brake cable and conduit to the left rear parking brake cable bracket (2530).
For intermediate cable installation, feed cable through holes in center frame bracket.
Attach cable to front parking brake cable and conduit and to left rear parking brake cable bracket.
As far as releasing pressure from the cables, here are a few ways to do it.
Place the parking brake control (2780) in the "released" position.
Parking Brake Control
While an assistant relieves tension on the system by pulling on the parking brake intermediate cable, insert a 4mm (5/32-inch) , steel pin or equivalent drill bit into the hole provided in the parking brake control.
NOTE: Be careful not to damage the plastic coating on the cable strand. Remove the parking brake rear cable and conduits (2A635) from the parking brake cable bracket (2530).
Another method, which releases tension on the parking brake rear cable and conduits only, is to pull rearward on the parking brake rear cable and conduit about 25-50mm (1.0-2.0 inches) and place a clamp on the parking brake rear cable and conduit behind the rear frame crossmember (5035).
Another method which can be used is to remove the bolts attaching the parking brake control to the floor pan, and pull the parking brake control upward and forward to rotate the spring-loaded ratchet wheel as far as possible.
I hope this helps. Let me know if you have other questions.
Cheers and happy fishing!
Apr 14, 2021 at 10:39 AM
(Merged)
