left rear turn signal not working
2004 ISUZU AXIOM
110,000 MILES • V6 • FWD • AUTOMATIC
CINDER4062
  • 36 POSTS
the front left turn signal starting flashing fast so I check the front and then the rear turn signals and that's how i found out that the rear left turn signal was not working so i proceeded as normal and changed the bulb but not like normal this did not solve the problem. I've tried both new bulbs, I've even tried using the bulb from the right side and still not working. So now I have no clue since all the other bulbs work( brake, back up). Can you tell me what I should try next and what tools if electrical and how to use them if need be. Thank you in advance for any help
Jul 22, 2014 at 9:16 PM
KHLOW2008
  • 41,814 POSTS
You need a test light or DVOM to check if power supply is available at the bulb socket before proceeding with further diagnosis.
Jul 24, 2014 at 9:12 AM
