Left rear turn signal/brake/reverse light
2007 LINCOLN NAVIGATOR
160 MILES • 5.4L • V8 • 2WD • AUTOMATIC
EL JR
Left rear turn signal/brake/reverse lights dnt wrk. Night lights turn on but the others dnt.. Ive checked all bulbs switch bulb connectors from right to left and nothing i also tested all fuses and no luck... Looked for a flasher relay and am not locating it
Nov 6, 2015 at 2:11 PM
HMAC300
  • 48,601 POSTS
this may be a smart junction box problem there are flashers for left and right frt and rear but they may not be replaceable. there is a parking light relay as well you can try replacing that or checking it at our how to repair elecetricl how to check a relay. there is also a trailer brake module if you have that. but scanning will be required to find the cause as smart box can put one side out any pro with a pro scanner can do this that have one.
Nov 8, 2015 at 9:10 AM
