Is this bracket only supposed to be held to the transmission with one bolt on the side? This bracket has an additional 3 other holes that line up with 3 on the transmission body. But those holes have no thread. The mount itself has 3 that are used to bolt it down as well as the center hole that takes a long bolt to connect the mount and bracket together. 1 bolt to hold the bracket to the trans seems like it would bend easily. So is it a bad designed and it really only takes 1 bolt?
Oct 14, 2019 at 11:51 AM
