LEFT REAR BRAKE LIGHT WILL NOT WORK BUT THE RIGHT SIDE IS WORKING.
1994 LINCOLN TOWN CAR
132,300 MILES • 4.6L • V8 • RWD • AUTOMATIC
RANDALL729
  • 59 POSTS
Left side running lights, left side turn light, left side reverse light all work but not any brake stop light. The bulbs are 3157. Right side works with no problems and also Third upper brake light. Should I tap a wire from the Third light or the right side brake stop wire. in order to get the left side working? The ground wires must be good if the other functions operate? I am really confused about this so was asking for any advice.
Feb 6, 2016 at 6:22 PM
CATAFINA
  • 167 POSTS
You can go either way up to you
Feb 7, 2016 at 12:09 AM
HMAC300
  • 48,601 POSTS
probably your multi function switch bad
Feb 7, 2016 at 8:41 AM
