Left headlight high beam failure?
2007 CHRYSLER SEBRING
149,129 MILES • 2.4L • 4 CYL • 2WD
PETER1974
  • 13 POSTS
The high beam on the left doesn't work, I'm sure the bulb isn't broken. what's the problem?
Aug 1, 2022 at 12:58 AM
Chances are the bulb is no good. here are instructions in the diagrams below on how to change out the headlight bulb. Here is a video of the job being done on a similar car, it should help as well:
https://youtu.be/Kt2aA4Fk5J4
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 1, 2022 at 1:17 PM
PETER1974
  • 13 POSTS
I changed the bulb, and it still doesn't work. I have a spare TIPM fuse box to replace the high beam problem perfectly solved.
Aug 12, 2022 at 1:48 AM
Nice work, I thought that could be it, but I don't like to say that is the problem when it is just a bulb. We are here to help, please use 2CarPros anytime.
Aug 12, 2022 at 11:13 AM
