Air conditioning seems to work through left and right vents; however he only comes in from the right vent.
I'm trying to replace the blend door motor.
There are two screws I can access the bottom one easily:
1) How best can you access the talks good that is not easy visible?
--- does anything need to be removed?
2) There was a red clip on the wiring harness, I removed to get it out I assume that was just a retaining clip that should go back?
This is video and part on YouTube but for 2014, mine is 2017.
https://youtu.be/MxpWuDjD8VQ
Oct 21, 2022 at 9:38 AM
