left front end noise
2011 TOYOTA CAMRY
60,000 MILES • 4.5L • 4 CYL • 2WD • AUTOMATIC
PETER BOWKETT
I have a rubbing like noise coming from the front end left side of my car the faster I go the faster the sound . I have checked the CV joints which are okay. I have two scratch marks on the rotor but I have not checked the brake pads. could it be coming from there or what else could it be?
Apr 19, 2017 at 6:19 PM
JOHNNY G.JR
  • 320 POSTS
Jack that tire up off the ground and spin tire, inspect inside of wheel well for an obstruction with tire removed.
Apr 19, 2017 at 6:55 PM
HMAC300
  • 48,601 POSTS
if the noise goes away when you press the brakes it may be the brake sounder meaning you need a brake job, it will give a screeching type sound. you might also drive in a circle opposite of the side you think it is on if it is louder on one side than another then it may be a wheel bearing.
Apr 20, 2017 at 6:15 AM
