I am trying to get the part out of the transmission and cannot find the clip that is holding it in. So I can replace the drive axle.
Oct 4, 2016 at 4:09 AM
HMAC300
CERTIFIED EXPERT
the clip should be on the axle if not it is stuck in diff part of transaxle.
Image (Click to enlarge)
Oct 4, 2016 at 6:28 AM
BLAZEK
MEMBER
Thanks. So that means the housing around it has to be moved to assess the clip?
Oct 4, 2016 at 12:40 PM
HMAC300
CERTIFIED EXPERT
well you could shine a light in there and try a picture of some sort to get it out if you do not see one it fell out and is either on ground or frame of car. you should see a small groove though.
Oct 4, 2016 at 3:08 PM
BLAZEK
MEMBER
This is what I am looking at.
Oct 4, 2016 at 6:11 PM
HMAC300
CERTIFIED EXPERT
stick a large screwdriver or flat bar where arrow is and push on axle it should come out unless this is rear wheel drive then there will be four bolts holding it at backing plate.
Oct 5, 2016 at 6:28 AM
BLAZEK
MEMBER
It is front wheel drive. This is the driver side. Will try. Thanks
Oct 5, 2016 at 6:46 AM
HMAC300
CERTIFIED EXPERT
just curious have you pulled the main nut and wheel off yet? if not you will never get the axle out. see picture.
Oct 5, 2016 at 7:17 AM
BLAZEK
MEMBER
This is what I'm looking at where the drive axle come out of. I have tried slide hammers and even the vise-grip method to try and get it out. Even tried to use a pry bar on the other side.
Oct 16, 2016 at 11:27 AM
HMAC300
CERTIFIED EXPERT
take the bolts out around the shaft and see if whole mess will slide out.there may be a bearing or bushing frozen to axle then you can take the bolt part off of axle to see what is really wrong.
