You will get lean codes with the engine misfiring; did you clear the codes after the tune up? Also, how did the spark plugs look? This engine has a fuel pressure regulator which I would remove the vacuum line from, if gas is present the regulator is bad, here is the location so you can check it out.
Even though you have a new fuel pump it could be defective. I would do a pressure test by following this guide.
You can rent the gauge at the auto parts store for cheap or free. If you have low fuel pressure you will smell gas when the engine is hard starting.
Measure with the Key On Engine Off with the fuel pump commanded ON.
Vin (V,T,U)
Fuel Pressure (gasoline) .................... 55-62 psi
Vin (Z)
Fuel Pressure (ethanol) .................... 48-54 psi
These specifications are taken from the Fuel System Diagnosis. For complete testing of fuel pressures and volume see Fuel System Diagnosis, See: Computers and Control Systems > Testing and Inspection
This guide can help as well
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Check out the images (below). Let us know how it goes.
Jul 22, 2024 at 10:26 AM
