Lean code on bank 1 and 2
2005 FORD TAURUS
104,500 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
NICKTODD
I keep getting a lean code for both banks (bank 1 and bank 2) and i cannot seam to figure out why.
Aug 19, 2017 at 11:54 AM
You will get a lean code on both banks if the MAF sensor is bad and needs to be replaced. When this sensor gets a little off it will cause the fuel delivery to be off because the computer sees it as less air going into the engine and gives it less fuel. This kind of problem may not give a MAF code.
Here is a guide to help you get the problem fixed:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Here is the part:
https://www.amazon.com/gp/product/B00BG3WVTI/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B00BG3WVTI&linkId=61e8417afd101b688e7bc8341c92a156
Aug 20, 2017 at 12:03 PM
