leaking transmission fluid
1995 HONDA ACCORD
200,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
MIKEWIZZY
I noticed my 95 honda accord LX was leaking transmission fluid. So I took a look at it and there was transmission fluid around the axles, so I was assuming it was the seals. So I went ahead and replace them. But somewhere transmission fluid was leaking out. Then I noticed there was a hose on top of the transmission under the motor mount. I do not know where that house goes to. Any suggestion???
Feb 11, 2016 at 12:36 PM
HMAC300
  • 48,601 POSTS
it may be a vent hose usually leaks from being overfull normally
Feb 11, 2016 at 1:13 PM
MIKEWIZZY
So that's normal for transmission fluid to leak out from that house? Does that mean that my transmission is to full?
Feb 11, 2016 at 1:30 PM
HMAC300
  • 48,601 POSTS
not it's not normal have a trans guy check this it may be a pump problem or something else.
Feb 11, 2016 at 3:55 PM
MIKEWIZZY
OK thanks you your advice I'm going to have it check out tomorrow.
Feb 11, 2016 at 4:00 PM
