how do I remove the power steering gear box? How hard is it to replace the seals?
Mar 1, 2015 at 10:34 AM
HMAC300
CERTIFIED EXPERT
your best bet on this is to get a rebuilt one instead of doing it yourself. Unless you have ever redone seals then you can really screw it up . If it is just the pitman arm seals the hardest part will be getting pitman arm off and you need snap ring pliers to replace the two seals inside.
