Leaking oil, idle bad after valve cover replacement?
2005 INFINITI G35
268,095 MILES • 3.5L • V6 • 2WD • AUTOMATIC
HOLLYWOOD421
I had a valve cover, spark plugs, coil packs and oil changed all at the same time. Soon as I got the car back, I noticed right away while idling it would drop down and almost stall. I was told it had to relearn things again, but it has been 2 weeks and it’s still doing the same. And it's also still leaking oil. It’s only been 2 was and I just checked oil and it was almost completely gone!
Feb 10, 2023 at 8:12 PM
As far as the leak is concerned, if it is still coming from the repaired part, the shop needs to take care of it at no charge.
The idle is different. I suspect that when it was worked on, someone left a vacuum hose disconnected or broke one. That will cause idle issues, and the relearning time is over within about 5 miles.
Here is a link that explains how to locate a vacuum leak:
Feb 10, 2023 at 10:13 PM
