Is there a specific area that this leaking from? More then likely this is a pan gasket but it could be a seal so we need to try and narrow the area in order to figure out what this could be.
Either way we are going to need to clean the transmission of all the fluid and grim so that we can try and find where this may be coming from.
Just use a spray cleaner from a parts store and then start the engine and lay on the ground to try an find the general area and then we can go from there. Thanks
Sep 27, 2020 at 6:56 PM
