leaking of coolant inside
2009 HYUNDAI I10
9 MILES
ARUNKUMARCHAUHAN
hi..
i have an serious problem in my car..the floor of car in the driver side is found wet..when i removed carpet than i found tht it is wet from a gren liquid.the workshop is so far..so pls tell me how to fix this problem..when i saw from whr this was coming thn i get sign of coming from the bottm vent for ac air which is for foot..so pls tell me the solution..i can do it myself..if possible pls send the picture of tourbleshooting also
May 19, 2013 at 2:31 AM
KHLOW2008
  • 41,814 POSTS
We don't have any information for your vehicle so I don't have any diagrams for you.
The green fluid should be coolant and that means the heater core is leaking. If you live in a country that do not need the use of a heater system, you can plug off the heater hoses from engine side.
You need to be checking the engine coolant level and have this ectified asap, failing which you could damage the engine due to overheating.
May 19, 2013 at 2:45 AM
