I have been told that my head gasket is leaking. Oil is showing up on garage floor and leaking onto some portion of the exhaust and smoking. Last oil change the mechanic overfilled the car with oil. Car would get pretty smelly after a 10 - 15 min drive.
A different mechanic said via phone he would need to test the car with engine cold and that oil does ot usually leak from a head gasket. Subarus have a known issue with their head-gaskets.
Can you diagnose a failing head-gasket via a visible inspection or do you need to test antifreeze etc?
Mar 24, 2017 at 4:26 PM
