Leaking dome light
2005 PONTIAC GRAND PRIX
195,000 MILES • 6 CYL
PIECEOFJUNK
Every time it rains the dome light leaks a stream of water.
Nov 7, 2018 at 7:58 AM
JONNYB1963
  • 263 POSTS
Do you have a sunroof on that vehicle?
Nov 7, 2018 at 8:04 AM
Hi and thanks for using 2CarPros.com
Chances are you have a sun roof. There are drains located between the window and body that can plug with dirt and debris. Here are the directions for checking and correcting this problem.
_______________________
Sunroof Drain Inspection and Cleaning
Drain Hose Routing
A drain trough encircles the sunroof window panel and water is drained off by the drain hoses located at each corner of the housing. A drain channel spans across the sunroof module at the rear of the window panel and directs water into the trough.
1. Check to ensure the front drain hoses are routed down the windshield pillars and out the center of the pillar between the door hinges. Make sure the hoses are not kinked.
2. Check to ensure the rear drain hoses are routed through the rear pillars and out of the rocker panel. Make sure the rear hoses are properly routed in the metal roof slot and taped in place.
Plugged Drain Hose
If a water-leak has occurred check for a plugged drain hose at each corner of drainage system.
1. Open the sunroof window.
2. To test for blockage, pour a small container of water into the module housing drain trough. Check each corner to confirm the drain hose is draining water.
Caution: Wear safety glasses in order to avoid eye damage.
3. Use compressed air, 241 kpi (35 psi) or less to blow out any drain hose that is plugged.
4. Test the system again.
5. If the hose remains plugged, check to see it is properly routed and does not have a kink. Refer to Drain Hose Routing.
6. Remove the blockage using the following steps.
1. Push mechanics wire through the hose to remove the obstruction.
2. Use compressed air in order to blow out any remaining material.
Disconnected Drain Hose
Inspect the drainage system for disconnected drain hoses. Complete the following steps in order to obtain partial access to drain hoses and check for a disconnected hose.
1. Open the sunroof window panel.
2. Lower the headliner as needed. Refer to Headliner Replacement in Interior Trim.
3. Connect any disconnected hoses.
4. Ensure that the rear drain hoses are properly routed in the metal roof slot and taped in place.
__________________________--
Let me know if this helps or if you have any other questions.
Nov 7, 2018 at 7:43 PM
