There is oil coming out inside the timing belt cover. I believe it to be the seal behind the crankshaft gear. My question is regarding the plate/housing behind the gear that the seal presses into. It appears to be separate from the block so is there a gasket or o ring that could be leaking behind the plate? Here's one seal kit that is offered and it appears to have a gasket and 2 o- rings. I'm not sure if it's for the 1.9T or not. Could be for the base 2.0.
Aug 18, 2023 at 1:08 PM
