Leaking coolant
2015 CHEVROLET TRAX
105,000 MILES • 1.4L • 4 CYL • TURBO • 4WD • AUTOMATIC
BLAIR BATTEN
When my SUV heats up, she pulls coolant out of the holding tank. Would the thermostat make it do this or is it the radiator cap?
Feb 15, 2022 at 4:58 AM
SQM
  • 6,383 POSTS
So, is the coolant coming out of the cap?
A bad or weak radiator cap will allow coolant to escape, due to not being able to hold the proper amount of pressure when the engine is running at the operating temperature.
Are you experiencing any overheating? If not, then it is likely just the cap.
Those caps can be tested with a cap pressure tester. That will tell you if it is holding the correct pressure. Those testers are available at your local auto parts store to use.
You can also do a pressure test of the cooling system to determine if the leaking from any other component.
Here is a helpful guide:
https://www.2carpros.com/articles/radiator-pressure-test
Keep in mind that you do not want to remove the radiator cap when the engine is hot.
Wait for it to cool down first.
Thank you.
Feb 15, 2022 at 1:25 PM
BLAIR BATTEN
Thank you very much.
Feb 15, 2022 at 4:41 PM
Is the fan coming on? Also, do you notice any leaks on the ground? Here are two guides that can help us fix it:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Feb 15, 2022 at 4:43 PM
